It is currently Mon Aug 04, 2025 3:58 am
PostPosted: Tue Feb 24, 2009 11:38 pm
First name: tomas
Last Name: gilgunn
City: sligo
Country: ireland
hi again just wanted to know if anyone made a home made intonatior
where you got the bits from any everyday things you can use for one?
PostPosted: Tue Feb 24, 2009 11:45 pm
First name: joe
Last Name: kelly
City: glasgow
Country: uk
hi wolfsearcher ,,,,i used a bit of ebony for the body and drilled it for string spacing....i also shaped the ebony to fit the curvature of the bridge i then used cheap allen keys t make the saddles which i held in place by wood screws that had the tip filed flat....
joe
PostPosted: Wed Feb 25, 2009 12:45 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
It looks as though you could get a brass or aluminum rod of the right size and drill and tap the hole then use a machine screw matching the thread and that would go into a holding fixture... I honestly would not bother with an "intonator" because as soon as you correctly calculate the proper saddle position (you use twice the distance of the 12th fret from the nut then add 1/16" to the treble side, 5/32" to the bass side and draw the angle) it should be pretty darn close, then you can file the saddle to further fine tune your intonation (shouldn't be needed). Then either use an earvana compensating nut, or make your own compensating nut and everything should be spot on.
Typhoon Guitars
PostPosted: Wed Feb 25, 2009 1:59 am
A Peterson V-Sam, dummy saddle beveled to the front, and a bit of simple math. I've never really felt the need for an adjustable intonator - too much hassle without necessity or benefit in my opinion.
PostPosted: Wed Feb 25, 2009 2:50 am
First name: joe
Last Name: kelly
City: glasgow
Country: uk
i totally agree david.......intonaters are way to much hassle for such a small benifit.....
PostPosted: Wed Feb 25, 2009 3:51 am
I save those bits of "G" string I trim off when ever I change a set of strings. I cut off about an inch of the wound part of the off cut leaving a 1/2" of unwound string still attached. I then bend the 'unwound' part of the string at right angles a little less than half way up creating small right angle leg about 3/16" long.
Backing off some tension from the string I wish to check and using the wound part of the little "G" string hockey stick I just made as a handle, (the windings offer some grip for the fingers giving better control of the tool) I then slide the small unwound right angle leg in-between the top surface of the saddle, and the string I am intonating.
I bring the string back up to pitch and check the intonation. If it is incorrect, I back off the string tension a little and move the little hockey stick leg either back or forward across the top of the saddle to pin point the intonation position with the string at pitch. Once found, I mark the saddle ready for filing at that position indicated by the leg of the little hockey stick.
Cheap and effective [:Y:]
PostPosted: Wed Feb 25, 2009 6:01 am
What Kim said, exactly, except that I use the other end of an old G string, so that I have not only the windings, but also the ball end, to help hold onto the little tool I've made. Like Kim, I remove the windings from the part that I bend into a little L to go under the string. I use a Peterson VS-II virtual strobe tuner.
Todd Rose
Ithaca, NY
PostPosted: Wed Feb 25, 2009 10:38 am
I've been using pieces of string, but will now be using the ballend/wound part!
Tried that Stewmac intonator some years ago, sent it back. Nice in theory, but...
https://soundcloud.com/jeffreylsuits/he ... -runnin-13
PostPosted: Wed Feb 25, 2009 10:56 am
First name: Tai
Last Name: Fu
City: Taipei
Country: Taiwan
Like I said you get fairly darn close just calculating it mathematically anyways. I mean if you want you could try the intonator but I mean you find the position (stewmac even offers a fret/bridge position calculator) and use a wider saddle and adjust accordingly. My first guitar I was actually off by quite a bit and most guitarists couldn't tell the difference. I corrected it and calculated correctly and it was spot on in the tuner (maybe off by two ticks).
Typhoon Guitars
PostPosted: Wed Feb 25, 2009 4:08 pm
First name: tomas
Last Name: gilgunn
City: sligo
Country: ireland
Thanks so much guys for the exelent advice tomas
PostPosted: Wed Feb 25, 2009 4:45 pm
I have used the Stewmac intonator. I think it would be good for those that slot the saddle slot after the bridge is installed and then if they use a single straight saddle they only need the outer two drums to define the angle of the saddle. it would also be helpfull to those that use individual saddles segments for each string. However if you slot your bridge prior to installation they are useless
I use a 3/32” wide Martin style saddle and I pre slot my bridges. I shape the saddle with a radius top to first get close to the proper action + the saddle radius height. I hen file out the radius bring me to final saddle and action height. While the saddle has a flat upper surface I use the “B” string method to finesse the proper intonation break point. I say finesse because prior experience has taught me that with a properly precut slot in my bridge and using the Luthiers tools bridge and centerline locator jig adapted to locate my bridge position by means of pins that index the outer pin holes and hold the bridge square to the centerline the locate to “1st” string position of the saddle slot to a pre marked scale position on the long base of the jig. I am able to locate my bridge so that even if I did no intonation adjustment I will bee within 4-6c (less variance than most untrained human ears can hear) of true pitch with the break point at the center of saddle. Now that said I still always need to lengthen the “B” string some and I always go through the intonation process to proof out and finesse.
SO if I had to say what I think is a great home made intonation tool I would say it is the Luthiers tools bridge and centerline jig adapted to index the saddle slot and hold the bridge square to the centerline of the jig. That and a used piece of “B” string and my VSII
PostPosted: Wed Feb 25, 2009 5:13 pm
wow7-eyes oops_sign Luthiers Suppliers centerline locating fixture !!!!!!!!!! not luthers tools Sorry Tracy :oops:
Users browsing this forum: No registered users and 61 guests
